Ana içeriğe geç
MacBook Air models with 11" displays
984 Soru Tümünü görüntüle
Power button not working
A MacBook A1465 came in today with no power, took it apart tested it all out, found that the power button doesn't work and everything else seem brilliant, my question is can I just replace the keyboard or do I have to replace the full uppercase? TIA
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here's the part: http://www.ebay.com/itm/Replacement-US-S...
Here's a video on doing it: https://www.youtube.com/watch?v=knI4Bgd7...
Here's how to pull the rivets: https://www.youtube.com/watch?v=djnOVxzb...
I replace the rivets with screws in a kit like this:
https://www.amazon.com/Replacement-US-Ke...
Bu yanıt yardımcı oldu mu?
Puan 5
Yorumlar:
awesome mate, thanks, im in the uk and would need it asap
would this work http://www.ebay.co.uk/itm/APPLE-MACBOOK-...
also is it important to replace the rivets with screws, the reason i ask is they take two weeks coming to the uk and i want to get it done asap
tarafından
@reecee may know of a supplier in the UK
tarafından
@krayzee yes that part is fine. You'll need to order screws too (search on eBay for a1369 keyboard screws). Make sure it's not an issue with the trackpad cable (sometimes this can cause an issue with the power button, instead of the keyboard).
You don't need a backlight, you can reuse the old one if it lights fine, so you should be able to get it for cheaper. As long as it is an A1465 2011-2015 keyboard, it will work fine
tarafından
@reecee This comment is what saved my machine. Power button not working, and saw evidence of a liquid on the keyboard. I replaced the keyboard but the problem persisted. Checked the trackpad cable (thanks to your comment) and the connector was severely corroded. Replaced it and now the machine is fixed. Thank you!
tarafından
@tburns4 glad it helped you. You thank a answer provider by uo voting the answer
tarafından
Yorum Ekle
Yanıtını ekle
Krayzee sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 22
Son 30 gün: 47
Her zaman: 3,811
