Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
861 Soru Tümünü görüntüle
The Brown cable hold down breaks when you remove it.
The brown connector breaks as soon as you pull it straight out to take the wire out in step 3. It has two little arms with hooks and one arm is now gone. How do I reassemble my ipod (reverse step 3) since you didn't supply a new brown connector with the new cable? This should come with the cable assemble.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I can tell you of hand without exactly knowing which cable or part on the iPod video you replaced, that none of the cables or parts come with replacement clips. All the connectors have PERMANENT clips that push on the cable and thus cause the connection. You can try to find a clip from another logic board of same kind and see if you can replace it. This is very tedious and will require some good magnification and dexterity. Personally I think you may have to replace the logic board. But give us some more info and we will see if we can help you further. Good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Joseph Hart sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 462
