How do I replace door
How to replace door on kenmore microwave
Bu iyi bir soru mu?
Unplug the microwave and set it on a table or workbench. If you have a built-in microwave, you may have to remove
some mounting screws or retention clips to get the microwave out of the support bracket. Open the door and take out the
glass tray.
Pry off a corner of the plastic panel on the inside of the door with a screwdriver or butter knife. Once it is loose, work the
screwdriver or knife all the way around the glass and remove the panel.
Ask someone to hold the microwave door as you disconnect it from the hinges. Depending on the design of your
microwave door, you may have to remove a set of screws or slide a pin out of the hinge to release the door. Remove and
discard the old door.
Have your assistant hold the replacement door up to the hinges. Attach the door to the hinges by reversing the previous
step. Snap the plastic inner panel into place around the glass. Move the microwave back to its original location. Insert and
tighten the necessary mounting screws if you are working on a built-in microwave. Set the glass tray back inside the
microwave and close the door
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 2,379
1 Yorum
Hey Richard! What exact model of Kenmore Microwave do you have? Is the whole door broken, are the hinges sticking, or is it just not locking into place? Give us some more detail so we can help. There are plenty of Kenmore parts and door repair videos out there, so we should be able to find something to help. Thanks.
Kelsea Weber tarafından
