Screen doesn't always turn on
When I turn on my computer, sometimes the screen wont turn on. By that I mean there is no backlight and from what I can tell, no faint picture on the LCD. I know that the computer is starting up fine since I can login and play a audio file on my desktop.
The only thing I've found that fixes it is resetting the SMU and PRAM but that doesn't always work and the next time the computer is restarted the screen usually wont turn back on.
Any suggestions for what could be a cause of it? I thought it could be the power supply, inverter or LCD but I'm not sure since it sometimes works.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Does your computer fall into this range?
Serial Number ranges:
  • W8435xxxxxx – W8522xxxxxx
  • QP435xxxxxx – QP522xxxxxx
  • CK435xxxxxx – CK522xxxxxx
  • YD435xxxxxx – YD522xxxxxx
Bu yanıt yardımcı oldu mu?
Puan 2
Yorumlar:
Nope, its got a W86xxxxxxxx serial number
tarafından
Good, no bad caps issue. Now hook it up to an external monitor and see if both go out at the same time. If so it's the GPU. If not then replace the inverter (cheapest) next the screen.
tarafından
I have yet to hook up a external monitor but I started it up today and the screen turned on. The interesting thing is that when the computer goes to sleep and screen turns off, when I wake it up, the screen always comes back on. I don't know if that changes what the cause could be.
tarafından
What is the caps issue if the serial is in that range? Thanks
tarafından
Yorum Ekle
Yanıtını ekle
Clever Error sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 1,250
