Ana içeriğe geç
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
79 Soru Tümünü görüntüle
Why is my break light staying on?
Why is my dashboard break light staying on when I'm driving? I've checked my break pads and they're pretty new.
Bu iyi bir soru mu?
Puan -1
2 Yorum
A little more information would help. Is it on when the car is off? Is it dim or bright? Do you get a dashboard brake indicator?
tarafından
Your external brake lights are on or the internal (dash) brake warning light stays on? like mayer said, we need more info please.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
christy, it means one or more of the following, the brake fluid is low, the parking brake lever is either up or the circuit for the parking brake switch is shorted, or if the battery light is also on, the car needs a new alternator. Also check your rear brake lights and make sure they are all functioning. Since we are talking brakes here,you should have a mechanic check it out for you. Hope this helps a bit and good luck to you.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
christy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 7,084
