Ana içeriğe geç
2012 yılında üretilmiş iRobot Roomba 655 Pet Serisi robot süpürge. Costco'ya özeldir.
Side brush isn't working.
The side brush isn't working anymore. I've replaced the entire side brush unit and it will do a .25 revolution once it starts cleaning then the side brush will not work. I've striped it down and cleaned everything that could be cleaned. I am At a loss here no idea what's up and I-robot told me to buy a new one when I called the help line.
Bu iyi bir soru mu?
Puan 0
1 Yorum
Did you solved the problem? I have the exact same thing, replaced the module, still not spinning :-(
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@bobo006, Ben, If you have already replaced the side brush motor and still not working, check the wires and connector for being, loose/damaged/corroded/check the connector with DVOM to ensure power is getting to the motor and make necessary repairs if defect found. If motor has not been replaced perhaps consider replacing motor. 1st link below is a guide to replacing side brush motor and 2nd link will get you inside to inspect the mother board for loose/damaged/burnt components. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
iRobot Roomba 655 Pet Series Yan Fırça Motoru Değişimi
iRobot Roomba 655 Pet Series Anakart Değişimi
iRobot Roomba 655 Pet Series Anakart Görseli
Kılavuz
Zorluk:
Zor
2 - 3 hours
iRobot Roomba 655 Pet Series Yan Fırça Motoru Görseli
Kılavuz
Zorluk:
Orta
10 - 15 minutes
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
My roomba side brush remains on. This happened after my roomba got wet. What can I do?
tarafından
Be sure the central screw on the brush is not too tight. Even though you can turn it with your fingers Roomba will detect a TANGLE if its too tight and shut it down.
tarafından
Yorum Ekle
Yanıtını ekle
Ben sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 4,368
