Ana içeriğe geç
What's the secret to the LCD shield screws?
I can't get the screws on the sides of the LCD shield off without stripping them. I've tried JIS000 and 00 and still can't get them out without stripping them. Are they 0000? Is there some secret combination I'm missing?
As penance for my ignorance, here are some pics of a phone:
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorumlar:
What a pro lol
tarafından
I couldn't get the LCD shield screws off either they wouldn't turn. I went to a store here in town and he said his trick was to place the screen/part over the edge of a flat surface like a table or kitchen counter. I could get 3 of them off but not the other side. He placed it up against the counter edge and didn't have problems taking out the problem 3 screws. Try that next time. I know I"m getting a premium screwdriver set too mine aren't cutting it.
tarafından
Yorum Ekle
MacBook Pil Tamir Setleri
Başlangıç $69.99
Buy Now
Başlangıç $69.99
Buy Now
3 Cevap
Filtre ölçütü:
You need a 0.6mm Tri Point screwdriver. It is a Y shaped tip.
What happened to this phone that it is bent?
Why don't you have the screen off so you can get at the screws?
Also, you must hold a finger at the end of the screw for more rigidity.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorumlar:
I really hope you can tell the device pictured is a 6 and not a 7....
tarafından
Yorum Ekle
http://www.appleoemparts.com/tools/tri-p... this is the one u want/need
Puan 0
Yorum Ekle
Seeing that your phone bent in a cure there is a possibility that the screws got bent as well if you can find a small screw driver to use then use it. If you still can seem to get the screwws out go to you local apple store and ask if they can do anything to help you.
Puan -2
Yorum Ekle
Yanıtını ekle
Josh W sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 Gün: 3
Son 30 Gün: 9
Her zaman: 468
