2007 Lincoln overheating when I use my front oversize load sign
I have pilot car and it overheats when I use front sign when I remove it it doesn't overheat. Could this be thermostat issue? Or what
Bu iyi bir soru mu?
Bu iyi bir soru mu?
No. Your sign is blocking air intake to the radiator. Try drilling a lot of air holes in it.
Bu yanıt yardımcı oldu mu?
Ok thank you.. but I had another Lincoln same sign set up and all never overheated. So could there be other issues as it makes gurgling sound when I shut motor off even when it's not hot.
Check your antifreeze level. That sound is most likely water boiling in your radiator. You may also need a new thermostat. Also check your radiator cap, it may not be holding pressure.
Ok will try new thermostat just replaced radiator cap. Thank you
Also check to see if your fan belt is intact.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 92
