Ana içeriğe geç
A 14.1 MP camera released in 2012. The Nikon Coolpix L310 support and repair information.
17 Soru Tümünü görüntüle
My camera keeps saying "Memory card is write protected" and won't let
My camera keeps saying "Memory card is write protected even though it is not. I am not able to format it either in camera. Please advice :)
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Ram,
Quick fix: Should see a small grove on the side of your card, opposite of the lock switch. If you cover it with a small piece of tape you should be able to format in your camera. Be careful not to cover the contacts also make sure you secure the tape as you don’t want it falling off. Best of luck!
Bu yanıt yardımcı oldu mu?
Puan 2
9 Yorum:
Thanks so much Alex :) I will try it and let you know.
tarafından
Alex, I just tried it and my camera asked me if I wanted to format it, said yes, formatted it and the camera asked me to turn it off. turned it on and it still says memory card is write protected.
tarafından
Is the lock switch positioned at the top or bottom of the card? Depending on the device it may be necessary to tape the actual lock, very thin layer (1).
tarafından
The lock swithch is positioned at the bottom of the SD card. I will try a thin tape later this afternoon and let you know. Thanks!
tarafından
@pickleballpro, When you use tape tension it well around the switch and make sure it doesn't cover any contacts.
tarafından
4 tane daha yorum göster
Yorum Ekle
Camera saying all my cards are write protected and they aren't
Puan 0
Yorum Ekle
Yanıtını ekle
Ram Seetharam sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 24
Son 30 gün: 93
Her zaman: 6,132
