Ana içeriğe geç
Asus ZenPad S8, Asus tarafından üretilen 8 inçlik bir Android tablettir. Haziran 2015'te piyasaya sürülmüştür. Model numarası: Z580CA.
Replaced broken screen but touchscreen doesn't work
Hello,
I've recently replaced the screen of a Asus Zenpad Z580CA. Haven't glued the screen on yet, just connected all the cables and booted it to see if it works. No issues with the screen itself, everything looks fine. But I have no response to touch. Anywhere i press there is no response, it's not a few dead zones, the whole screen isn't working. Should I replace the screen again or could it be that something is badly connected? And if so what cables/circuitboards manage the touchscreen?
Thanks in advance for the help!
Update (07/16/2017)
Resim
I have no idea what else I can try...
Help would be greatly appreciated
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
change your screan and try again
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
did you insert the touch screen flexible correctly?
Puan 0
4 Yorum:
I assume so.
Which ribboncable is the one that connects the touchscreen?
tarafından
i 'm not sure about the position of the cable itself usually every cable must be fit to the socket just make sure it is well positioned and locked
tarafından
Refitted all cables a few times now, cleaned all contacts as well. Both no luck
tarafından
are you sure the touchscreen is not broken? try another touch screen module hope work
tarafından
Yorum Ekle
Yanıtını ekle
Ziyedm sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 610
