Ana içeriğe geç
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
My S7 Edge's charging port is broken, it doesn't charge anymore.
I tried changing cables and the adapter but my S7 still won't charge. I bought my S7 Edge for over a year now.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
In many cases, the charging port is fine but has become clogged with debris. If your charging cable seems loose or falls out, try using a sharpened toothpick to gently clean gunk out of the charging port. You’ll probably be amazed at what comes out. After cleaning the port on my Galaxy S7, the charger worked like new again. Don’t use any moisture.
Bu yanıt yardımcı oldu mu?
Puan 5
3 Yorum:
With nothing to lose I tried this and couldn't believe how well it worked. After a year of frustration with my charging port your toothpick suggestion worked wonders. Thanks!
tarafından
I was asleep, phone was charging (Galaxy S7 Edge) I knocked my pillow off the bed and it knocked over a full pint of water that went all over my charging phone. I cleared up but left my phone charging. Was woken later by a strange alarm noise from my phone & a burning smell!
My charging port was fried! I tried using a fast usb charger and it got fried, totally ruining the cable. My only option for charging now is a wireless Qi type charger where you just lay the phone on the unit and it charges as if by magic! The downside of this is charging in the car & how do I trasfer photos, music etc to and from my laptop without using a usb cable?
I did just try cleaning out the port and saw the little bit of metal in the middle that goes into the slot in the small end of the usb plug was off centre and squashed up towards the top of the port. I gently bent this back down and tried yet another usb cable and hey presto, it started charging, no burning smell either so hopefully problem is now solved for me!!
tarafından
Like Jim's experience, I also was amazed and pleased to see how well this simple technique worked. Thank you Dennis.
tarafından
Yorum Ekle
The hard way to fix this is to open up the phone and change the charge port.
http://www.ebay.com/itm/OEM-USB-Dock-Cha...
The easy way to fix is to purchase a Qi Wireless charger. No more cables.
https://www.amazon.com/Choetech-T511-Wir...
Puan 1
Yorum Ekle
It sounds like the charging port is not work, go to a repair shop to change a new one.
Puan 0
Yorum Ekle
Yanıtını ekle
I'm A Hater sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 28,330
