Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
1951 Soru Tümünü görüntüle
iPhone 7 screen flickering
Hello, I have an iPhone 7 screen was cracked and replaced and now the screen flickers. What causes this and how would I fix it? I also have an iPhone 6S plus that does the same.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Does the original screen flicker if you re-install it?
Screen flicker is usually caused by improperly seated or dirty connectors. Take a closer look, under magnification to see if there is any debris impeding a good electrical contact. You can also clean both sides (flex & logic board) of the connector with IPA (>90%). Sometimes, the retaining bracket has to be installed completely before flicker goes away.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorumlar:
That looks like a defective screen. Do the IP7 and IP6S do exactly the same thing? If so, you may want to consider changing suppliers.
tarafından
Yorum Ekle
Along with the flickering, it turns colors sometimes. It seems like certain colors triggers it. What do you think it would be? Maybe a cheap screen that was used?
Puan 1
Yorum Ekle
I have the same problem with my iPhone 7. Bought it without the screen then i have installed in it aftermarket screen to see if it works. Then i have ordered original, refurbrished screen and it was working fine for 3 months… then it started flickering. So i have bought another screen, again refurb, and after a month without a reason it started to act exactly the same like the one in the video. What can causing my screens to die? After puttin back the aftermarket display phone is working fine…
Puan 0
Yorum Ekle
Yanıtını ekle
CAB sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 29
Son 30 gün: 96
Her zaman: 22,872
