Ana içeriğe geç
Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
20012 Soru Tümünü görüntüle
Soru Kapandı
Won't run on battery alone
My macbook pro runs only when the AC adapter is plugged in. If you pull the plug it it dies and will not run off the battery. The battery is good, I have tested with a new one so it's not a bad battery. I have done SMC resets, I have not tried a fresh osx install. Short of replacing the logic board is there anything else I can do?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sounds like you may have a failing battery connector. Download and run Coconut battery to see what the status is and let us know and we can go from there. http://www.coconut-flavour.com/coconutba...
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Coconut battery looks fine, it detects the battery, says it's charging. When I check the charge status in the taskbar it says 20:00 until full. This will stay there no matter how long I keep it plugged in.
tarafından
Anything new on this post? I ran Coconut battery and it won't detect my battery. Any ideas?
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 4,187
