My charger will not fit into the port. How can I fix the charging port
The chargers will not go in. I think the charging port needs repair. How can this be done on LG Optimus L90
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Is the port bent? Are one of the prongs inside the port popped up? If either one of those is a yes. then you need to replace the port on the actual phone. If none of those is thne problem. Try getting a new charger and see if that works. Or try putting it in on an angle.
Goodluck!
-JR
Bu yanıt yardımcı oldu mu?
Yes the problem is the prongs are messed up. I tried with different chargers but nothing seems to work. Can you show me how to replace the charging port?
Thanks
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 58
Thanks
Abhi Shah tarafından
