Ana içeriğe geç
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
Touch screen won't work.
I replaced the screen and it all worked perfectly fine, but the touch screen will not respond to touch.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Make sure ribbon #2 is plugged in the whole way. It could be it didn't snap in fully.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
i tried that but the glass came off instead of the whole screen. what should i do? i think the sticky thing lost its stickiness.
Puan 0
Yorum Ekle
I had the same issue. I pulled the top screen part off even though I realize it probably wont stick as well as it used to. Then you can use a very thin small screwdriver to pry out the rest of the screen. Be very careful when doing so as the lcd screen is now exposed. Pry it from the outer edge between the case and the screen. I don't have my touchscreen working yet, but at least that will get you back into your phone.
Puan 0
Yorum Ekle
Yanıtını ekle
woodsidesk sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 2,750
