iPad Pro 12.9 touchscreen is unresponsive from time to time
I bought the iPad Pro 3 months after released date until now. Recently my iPad Pro sometimes unresponsive to any kind of tap but as far as I know 5 finger gesture still works but 1/2 fingers tap and swipe is not possible.
I can return to home just like pressing the home button by swipe with 5 fingers.
During unresponsive I cannot
- tap with 1 finger.
- swipe left and right with 1 finger.
- swipe with 2 finger
- zoom in zoom out with 2 finger.
I haven't made any update since I got it from Apple. iOS 10.2
At first I I tried to tap and it doesn't respond but keep tapping it sometimes works. Not so often but I dislike it when it occurs during gaming. Leave it rest awhile and it just back online as it used to be about a couple minutes.
So I made another test by using apple pencil when touchscreen is unresponsive and it works apple pencil works like normal.
I am never drop the iPad, nor crash it against something let say I am taking care of it like a little chid.
Update (06/01/2018)
Now I see where the problem came from. I leave the Apple Pencil battery to runs out completely. Now touchscreen is solved but when I plugged the Apple Pencil back just within a first 3 seconds I having a same issue again.
Update (09/23/2018)
After iOS 12 the problem still there even it’s a bit less but it seems to occur from some kind of angle and rotation. Shaking iPad Pro a few times seems to be the best way to fix the issue temporary. I have to shake it a lot when I am playing in bed.
Update (10/01/2018)
I think one of the problem that I believe in… Must be the iPad fault itself (bending). I mean the material that made or construct the iPad Pro is as thin as iPad mini so it is easily to bend.
I am noticed this problem because I am once visit the shop and staff put my iPad pro 12.9 on the table and told me that very very slightly of iPad pro is bend. I think because this bend causing touchscreen sensitivity to not working properly in some certain angle, especially in landscape mode. However I am still having problem in portrait mode also when playing Clash Royale. There are some kind of hardware system or piece that determine what angle of iPad pro is and rotate the screen for. So while this problem occur I am also seeing my iPad Pro doesn’t rotate when tilt to either from Landscape to Portrait or Portrait to landscape. Shaking like !&&* is one of the best calibration but only works in a short period of time.
When playing while on bed that iPad Pro is facing down to me, also making iPad sensitivity nearly stop working.
I wish I am still have a video that I took. You all should try by changing background to apple logo. While problem occurs or screen is freezing or sensitivity is bad, You will see Apple logo background is shaking like !&&*.
Background must be set to Dynamic to see how it works.
Sensitivity is bad while playing or typing, there will be some spot or whole touchscreen stop working in very short time but can come and go many times during a few seconds period.
Screen freezing will take a lot longer and whole iPad touchscreen is not working.
Both can be temporary fixed by Shaking real hard (make sure you are holding iPad firmly so it won’t fly out)
Update (10/10/2018)
I don’t have time to get a replacement but right now All I know is iPad Pro seems to choose the time of error by it’s own. Problem always occur at night while I’m in bed. Some kind of angle or iPad orientation?
Never have this problem while working. Could be an iPad orientation that cause this problem? or because of night shift?
Something weird in my iPad Pro.
I am no longer have this problem while using before 5 PM… But problem seems to start at 8 PM and more…
Update (10/11/2018)
Anyone have this problem of shaking iPad logo. I did a clean install already so it doesn’t have so many apps like in this video but shaking still be but less occurs. This problem doesn’t occur every time when touchscreen stop working but touchscreen 100% not working when this thing occurs.
I am noticing this because I did set my background as dynamic and only apple logo and by this I can see when problem occurs.
https://www.youtube.com/watch?v=4a-kgAZv...
Update (10/13/2018)
Buy a new one is best solution for now. Today i went to Apple care and staff cannot diagnosed my iPad problem but simply replied. It’s normal for any iPad under heavy usages for many years. They do not have repair policy here but instead return and giving me a new (with a %#*@ price)
I might wait for a new iPad to come and see who will sell their iPad in very good price and condition..
or grab a new iPad instead
Update (12/17/2018)
Ok now to the last update. I found out this problem also caused in iPad Pro 3rd Gen or to say both iPad 11 and 12.9 iPad Pro 2018 also have a sensitivity issue. After talking to Apple they already addressed the issue as Static electricity which will cause to some people. While iPad seems not working to me but it is still working with Apple pencil , Rubber tip pencil also working normally. Some of my family member can use while it doesn’t respond to my finger Because something has to be with electrical discharge and static electricity in your body and finger.
Because iPad Pro has a magnet inside while other iPads doesn’t.
Right now nothing we can do until Apple solve it.
Another thing, if you having this problem Go grab the Apple keyboard case it seems to solved this problem perfectly. Many of my friends in facebook group say the same thing that problem disappeared when attached to Apple smart keyboard (only works with Apple keyboard, not Magic or any bluetooth keyboard)
Update (12/20/2018)
My lastest information after I heard so many members in iPad Pro facebook group telling me that Apple smart keyboard folio can fix this issue so I did tried something different. Because I owned a Gen 1 12.9 iPad Pro so I cannot find old folio in Apple store, I got plastic case with magnetic cover from AliExpress instead and yes, now I can play this iPad Pro in any direction, Any angle, no more shaking background, no more unresponsive touchscreen. All gone. Just like a new one. So what people said about this must be true and because the display product in Apple store also come with Folio thats’s why we never see the display product having this problem. I believe the magnetic case discharge the static electric from the screen or from magnetic beneath the screen. I am also use a same old temped glass on iPad Pro 3 years ago so now that the glass is not the main issue.
For 3rd Gen iPad Pro, You still have to pick the Glass film wisely as some of them may causing face ID to not working properly and some causing the touchscreen have less sensitivity.
Update (01/18/2019)
iPad Pro gen 3 seems to work perfectly without any protective case and film or glass. Not the way we intend to use but as I keep watching people using them without any of these, They don’t have a problems (Some still but very low)
Update (01/20/2019)
Guys and Girls. If you have an old iPad Pro that already out of warranty. try to lower the battery and remove all the case and protective screen cover if possible. Visit Apple and asking for battery repair. Since Apple don’t have battery repair like iPhone they will give you a new one with a lot less cost. For Apple in my country will cost around 100 US$ for a new one. Just hope that your iPad won’t show any problems to their technician and perhaps you will have a chance for a new one with low price. I gave it to Apple and never mentioned even a single problem. They doesn’t seems to noticed too.
Update (05/19/2019)
Now I gotta say after a bit long wait, a few Apple care attempts for battery replacement and testing. I got a wonderful iPad Pro (New one). I did use my iPad Pro in insanely to drain the battery life down to 78% and I did talked to Apple for a battery replacement because they don’t have the same policy as the iPhone so they gave me a new one with a cost of 135 dollars to be exact for the same color and same capacity. Their policy doesn’t allow me to choose other color. I know that if they ran out of iPad Pro gen 1 2015 They will gave me iPad pro Gen 2 for me instead. After got the iPad Pro I am just simply plug in the Apple pencil directly, in front of Apple Care staff. No problem until now, no issue after all. BTW as a new iPad goes. I am now only using plastic/leather case and no any kind of screen protection because even I have very few scratches, when it’s time for the battery replacement they will give a new one anyway. The old one even have a scratch by accidentally once on the edge and Apple care doesn’t even mention about it.
Update (11/26/2019)
Now now with a new iPad Pro 2015 from the battery replacement program which Apple gave me a new one since then until now. Nothing bad happened to my iPad, No problem with touchscreen at all. It does upgrade from iOS 12 to iOS 13 and everything looks pretty good. I can’t say what exactly causes a problem with my first iPad Pro though but I can now rest and no longer frustrated with my new iPad Pro. Thank you Apple for this new one.
Update (09/26/2020)
After several months maybe almost a year. I can’t remembered but the updates that I made in my post keep me noticed for how long I have been using a new iPad that I got from battery replacement. Right now the new one have been working for me for very long and have no issue or any kind of issues like the first one did after 10 months of frustration using it. (Entered the program 26 Nov 2019) Now this replacement iPad still good and working like a charm but battery is now below 73% health and soon enough maybe good for another application of battery replacement again. I might try again next year. Wish me luck though that the 3rd iPad will have no problem.
Bu iyi bir soru mu?
162 Yorum
I am also have no sweaty finger too because I am only sweaty when using iPhone only (too hot for my finger)
Mr. Hymn tarafından
Right now I updated my iPad Pro and no problem just yet. But new update seems to make my touchscreen a bit too sensitive than usual.
Mr. Hymn tarafından
I also have iPad Pro 12.9 inch. Sporadically the touchscreen will not respond. I did all the updates and a full factory reset. Still does respond every now and then. Sometimes for 1-2 minutes, other times only for a few seconds. For $1100 I expect a lot more from apple. Not happy at all
DJ O tarafından
I have been having problems with my iPad Pro 10.5 for three months now. The screen often and arbitrarily ignores my touch, especially when I'm typing. I tried resetting and using different settings. Finally, I did a full reset, after many hard restarts, and it did not solve the issue. I'm starting to loathe my iPad.
Maidel Margulies tarafından
I have all the latest updates and now over the past 2 months I have times when I can not use the touchscreen because it does not respond. Not what I expect from Apple!
Liz Gaines Stiles tarafından
157 tane daha yorum göster
