Why don't my car grab gear right?
My escalade all of a sudden stopped getting the gears right. When I have it on overdrive it feels like it's being forced and I also have to give it more gas just to get it rolling. It wouldn't even make it up my driveway if I don't shift it to low 1 gear. When I give it gas I also hear like a humming sound from the engine. Does anyone know what this might be?
Bu iyi bir soru mu?
2 Yorum
How many miles does it have on it? When was the last time you changed the transmission fluid? Not a flush, those are sketchy, but just a fluid change? It sounds like the tranny is going out.
R Trent tarafından
It has 120,000 miles and the trans fluid was changed not to long ago. I was also thinking it might the transmission starting to go out. It's has 4x4 as well with the transfer case. Also I forgot to add that my "check gauges" light will come on and when that happens my RPM gauge along with my speedometer stop working. Then the little orange light where it shows what gear your on also disappears that's when it starts to run like #&&$. But every once in a while the gauges will work an orange light works, the truck drives normal without forcing to much on the gas, it's confusing. It sorta feels like I'm driving it on 4 wheel gear buy it's not. Also thank you very much for your comments and for trying to help out. Appreciate it very much.
Jerry tarafından
