Ana içeriğe geç
The third-generation HTC One smartphone which was first released in March 2015. Its major revisions on the M8 design include the octa-core Snapdragon 810 processor and a 20-megapixel rear camera.
71 Soru Tümünü görüntüle
Why is my phone acting weird?
My phone sometimes gets turned of and on by itself and this happens nearly everyday ... it once turned off and on over 50 times like that isnt normal... when it finally gets turned on my messages get deleted , i get loged out on every app and its pretty frustrating ... sometimes my power button doesnt work at all and i cant turn off my phone ... it has happened to me that my home screen button doesnt work too ...every time i touch the button it takes screenshots ..and also there are these two things that appear every now and then and dont let me do anything ..one tells me to press the volume up and power button to restart my phone and so but if i do that my phone wont turn on for a pretty long time and then the other one is the menu of power off, restart and airplane mode and i dont even press the power button ...when these things appear my power button doesnt even work anymore ...HELPPPPP PLEASEEEEEEEEEEEE
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
This sounds like a faulty power button. Did the phone get dropped or did it get wet? You may want to try using compressed air and blowing any dirt out from around the power button or taking the phone apart and inspecting and cleaning the power button area. If you take it apart clean with 99%IP alcohol and a soft toothbrush. Inspect the motherboard for burn marks or areas of corrosion . corrosion can be cleaned but burn areas require repair.
This guide shows the tear down procedure
HTC One M9 Motherboard Replacement
Hope this helps
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
My phone doesn’t let me call anyone and when the call does go through there are weird robotic type sounds. Anyone have a solution?
tarafından
Yorum Ekle
Yanıtını ekle
XhenaS sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 610
