Ana içeriğe geç
The third-generation HTC One smartphone which was first released in March 2015. Its major revisions on the M8 design include the octa-core Snapdragon 810 processor and a 20-megapixel rear camera.
71 Soru Tümünü görüntüle
Why wont my phone turn on?
my phone died today and when wanted to charge it all its says is 0% battery and turns off ... turns on again shows the 0% battery and then turns off .... its been more then 5 hours with my phone doing this ...it hasnt charged at all .... I NEED HELP, PLEASEEE
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You need to check your charging system . Try a different charger, check the cable and phone port for damage or dirt . If you need to clean the port use 99%ip alcohol and a soft toothbrush . A toothpick may also be helpful . If your port is loose or damaged you will need to replace it . It could also be the battery has reached the end of its duty cycle . This guide shows how to replace the charging port
HTC One M9 Headphone Jack/Micro USB Board Replacement
This guide shows how to replace the battery
HTC One M9 Battery Replacement
Hope this helps
HTC One M9 Battery Görseli
Kılavuz
Zorluk:
Zor
30 minutes
HTC One M9 Headphone Jack/Micro USB Board Görseli
Kılavuz
Zorluk:
Zor
30 - 40 minutes
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
XhenaS sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 105
