Ana içeriğe geç
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
612 Soru Tümünü görüntüle
Won't Boot - Mag Safe light stays orange, even when battery unplugged
No picture, no fans spinning. I've tried the I/O cable, power pads, and unplugging the battery and connecting the charger. The SMC reset changes the light of the charger to green temporarily, so the power button is working. PRAM did nothing of course.
The most unusual part to me is that the light stays orange, even when the battery is unplugged.
Here's a picture to prove I'm not crazy, forgive the quality:
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
9 Yorum
Hi! I'm having the very same issue with the exact same model - MBP A1502 (13" Retina).
It won't power up and the charger is amber EVEN with the battery removed. Does anyone have an update on the probable cause because it's a fascinating new feature I have never seen before and by the looks of it, it only affects the 1502
tarafından
Same issue too and model
tarafından
I have the same issue right now and I have no clue what to do… If anyone has more recent information I would love a way to fix this
tarafından
I have a MacBook Air 2017 13inch it have the same issue
tarafından
You all have logic board issues! You'll need to either find someone with the needed skills and tools to repair your logic board or just replace it.
tarafından
4 tane daha yorum göster
Yorum Ekle
7 Cevap
Filtre ölçütü:
En Yararlı Yanıt
That orange light is not supposed to happen with the battery unplugged. Did it liquid damage, or impact damage?
Unplugging the battery and magsafe, then reconnecting the battery first then attaching the adapter should cause a spontaneous re-boot. What does yours do when you try this?
Bu yanıt yardımcı oldu mu?
Puan 4
6 Yorum:
It does nothing, I was counting on that spontaneous re-boot. I work on MacBooks, and have never seen an orange light with an unplugged battery, hence this topic. The customer said there was no water damage, and the board looks great. The battery just fully charged, and Mag Safe went green. Still no boot. And when I unplug the fully charged battery, and re plug mag safe, it still goes orange.
tarafından
I thought I had seen it all, but this is a new one on me. Let's see if @danj has a clue.
tarafından
Thanks for giving it a shot. I've seen your avatar before in many other topics providing good answers. I'm going to see if I have a DC board for a 2015 to try, but it seemed to charge the battery like normal, turning green after it's been plugged in for 30 mins.
tarafından
@mayer & Davey0110 - I think you'll need to poke around the logic board checking the power rails. If the MagSafe charger LED goes to Green then that implies the one wire signal & SMC are working properly. But there's more to the logic than just charging. Here it sounds like either the switch logic MOSFET or a cap is shorted out. Basically this is a logic board repair issue.
tarafından
Thanks for your time Dan, I sent a query to Mr. Rossman to see if he has any input, since they have probably repaired a logic board or two.
tarafından
1 tane daha yorum göster
Yorum Ekle
Hello I have the same issue when battery is unplugged or pluged I have orange led on charger no water damage just stopped working anybody got the solution??
Puan 1
2 Yorum:
Any one with a solution
I’m also a victim just last night ..been frustrated till now
tarafından
take the base off. unplug the io board audio link cable and then try to start it. will not have sound, but does it work.
tarafından
Yorum Ekle
Please, I would like an update on the solution of this issue because I am also a victim of this problem as well. I tried changing the DC board from a working mbp still no effect. but one thing that I did observed was if I removed the MagSafe and let it run on a battery charged from another mbp, it does boot but if connected to the MagSafe it does not come on.
Puan 0
1 Yorum:
Your main logic board needs repairs
tarafından
Yorum Ekle
Spanish: Tengo una MacBook Air mid 2013 , el MagSafe siempre está naranja sin la batería y con la batería. No importa cuántas horas lo deje es igual. Así que la desarmé, lavé con Flux el powerjack y dejé desconectada la batería y viola! revivió. El problema es que si conecto de nuevo la batería se muere y no quiere encender. Tuve que dejarla una noche completa desconectada de batería y me permitió encender y actualicé por USB a 11.13.6
Creo que parte del problema es la placa de entrada de CC y la batería, pero hasta que no tenga otra para probar, no podré saberlo.
English: I have a MacBook Air mid 2013, the MagSafe is always orange without the battery and with the battery. No matter how many hours I leave it is the same. So I disarmed it, washed the powerjack with Flux and left the battery disconnected and violated! revived. The problem is that if I connect again the battery dies and does not want to turn on. I had to leave it a full night disconnected from battery and allowed me to turn on and update by USB to 11.13.6
I think part of it is the DC-In Board problem as well as the battery but until I get another one to try, I won’t be able to know.
Update (10/04/2018)
P.D. Conseguí un cargador MagSafe nuevo y original, de otro cliente y pasa igual , así que sigo confirmando mis sospechas con el DC-In Board
P.S. I got a new and original MagSafe charger from another customer and it's the same, so I'm still confirming my suspicions with DC-In Board
Puan 0
7 Yorum:
Hola tengo el mismo caso me gustaria saber si se pudo resolver con la DC- In Board David Moises
tarafından
Hola, tuvo suerte cambiando el DC-In Board? Me sucede lo mismo con ese modelo.
Have you had any luck chasing the DC-In Board? Same thing happens to me with that model.
tarafından
Hola, yo tengo el mismo problema. Tengo una macbook air 13 pulgadas de un cliente, le conecto el cargador y esta el foco naranja del magsafe, le desconete la pila y sigue el foco naranja, la laptop no enciende, no prenden los abanicos, nada. Le cambie el DC board y no ha funcionado, manana me llevaran unas laptop funcional, probare cambiar ese DC board y cambiar la tarjeta madre, les escribo que fue lo que pude descubrir. Lo mas seguro es que sea un problema de Tarjeta madre y necesite una reparacion mas a detalle en los circuitos.
tarafından
La solución fue cambiar el DC-In o powerjack y hacer un reset SMC y PRAM. Con eso el cargador volvió a verde cuando la batería está 100% cargada, cosa que antes era imposible.
tarafından
Sos un Savio Brother gracias te saludo desde California U.S.A. q estes vien
Te saludo desdes el cocktelito Express
tarafından
2 tane daha yorum göster
Yorum Ekle
Hello. I have same issue. MacBook air 13 2013 orange magsafe without the battery and with the battery. I have changed the DC Board to a working one but same problem with new DC board still in orange without battery and Computer does not turn on.
Puan 0
Yorum Ekle
This is WEIRD!
I installed a fresh clean MacOS High Sierra on my MBA 2015. Worked fine.
I then turned the mac off and left it for about a month.
I came back to it just the other day, and it won't turn on.
Plugged in charger - green light at first, then red light.
Ok, I thought it'll charge a bit and turn on (even though I do remember turning the mac off before I left for my break).
Came back after 30 minutes. Still won't turn on.
Thought it was the charger. Plugged in another charger (which works for sure). Same thing.
Weird.
Did all the reset BS that I found online (SMC, SM-this, SM-that, PM, PR, all that stuff). Nothing.
Opened it up for inspection. Looks like it's brand new (seriously - I take care of my stuff like crazy! A bit OCD on these things).
Disconnected battery and reconnected it. NOTHING.
What gives?
Anyone here has a clue?
Here are some pics:
https://imgur.com/uLsVAtI
https://imgur.com/Bq8cob3
https://imgur.com/G3A3BVf
https://imgur.com/a/MEAYUBB
Puan 0
Yorum Ekle
Gracias desde L.A el coctelito express
Puan 0
1 Yorum:
Did the shutdown happened (to never start again) while MBP was connected with power supply?
tarafından
Yorum Ekle
Yanıtını ekle
davey0110 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 77
Her zaman: 16,813
