Ana içeriğe geç
startup password on load up.
starts with standard error start up options. (ie. start norm, safe mode.....). whatever i choose brings me to a solo window asking for a startup password. how do i get rid of it? this has just happened randomly after getting a new battery.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
what OS are you using ?
tarafından
Can you put a screenshot from a mobile camera?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
You may need to remove the drive and using a drive caddy see if you can access it from another system. That's only if you need to backup data. Once you back up the data, then I'd reinstall the OS.
If you don't need data backup, you should just try to reinstall the OS.
You might spend hours upon hours trying to fix this, but if you are okay with losing your data or backing it up....you might be better off just re-installing the OS in the long run.
Good Luck!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Ben Krauel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 48
