Ana içeriğe geç
PlayStation 3 (veya daha sık bilinen adıyla PS3), Sony Computer Entertainment tarafından üretilen üçüncü ev bilgisayar eğlence sistemidir ve PlayStation 2'nin akabinde devamı olarak üretilmiştir. 11 Kasım 2006'da piyasaya sürüldü.
758 Soru Tümünü görüntüle
The PlayStation 3 hard disk's file system is corrupted
The PlayStation 3 hard disk's file system is corrupted and it doesn't restore when i press 'ok'; it keeps repeating the same message. what do i do?
Bu iyi bir soru mu?
Puan 9
5 Comments
Hold The Power Button 2 times Hold The Power Button For 3 seconds if its red do it 1 more time then it will give you instructions to set Up Safe Mode Press option 4 It Will reset the system then i think its gonna save your games
Thats All i know
tarafından
i have the same issue, but when i press the off button 3 times for more than 3 secs each, still the safe mode doesn't come up and the same error message about a corrupted file system appears again
tarafından
It work for a slight moment and then quit working and said corruption again after I restarted it again and again
tarafından
i am downloading saves online as i had to wipe out the whole data due to reasons and it shows corrupted what to do
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
1. Make sure the red light on your power button is RED.
2. Place your finger on the power button, and hold it down. It will turn green, then eventually go red. Give or take 10 seconds.
3. Release your finger. This lets the system know it's fixing to enter Safe Mode.
4. Then place your finger back on the power button, and hold it down.
5. It will beep once then twice, and THEN take your finger off the power button.
6.You should have a pop up on your screen that reads: 'Connect your controller to your USB cord, and press the PS button (The PS button is the one that has the PS logo on the controller). Do that with your controller,
7. then you'll have a list of Safe Mode options on your screen. Choose the one that reads, 'Restore your PS3 System.' On mine, it was option number 5. Could be different on each Gigabyte console.
8.Anyway...Hopefully some of you will see this, and save yourself time and money. Hope I helped you all out. =)
Bu yanıt yardımcı oldu mu?
Puan 22
30 Comments:
after i choose number 5 does it remove all of my files??
tarafından
Thanks it worked .. but it erased all my achivments :S :(
btw thanks alot (Y) u really helped me man :)
tarafından
How long does it take to restore
tarafından
how fast can you do this or does it matter in how fast can you restore the file system on Ps3 it doesn't say in how fast you can do this please explain to me how
tarafından
This works! Yes it deletes all the files but that’s a small price to pay to fix my PS3!! Thank you!!!’
tarafından
25 tane daha yorum göster
Yorum Ekle
This does not work with off-brand controllers :(
Puan 3
5 Comments:
Actually, you don't use the joystick for Safe Mode selection. Use the up and down on the D-Pad (looks like a cross!) to move the selection light. Hope this helps!
- Amy Cymore, Sony Inc.
tarafından
Thank you so very much for this information! I tried safe mode multiple times with different types of controllers and was about to give up, without realizing that the joysticks didn't work but D-Pad (which I never use) did. Within minutes I was able to restore my PS3 from a brick to a working system. THANK YOU!!!
tarafından
I used an iPlay controller just fine
tarafından
I only have an aftermarket controller it does not let you connect to the ps3 at all while it’s it. Safe mode. The screen stays on “connect the controller using a USB cable, and then press the PS button”
tarafından
Please I followed the steps and am able to restored it, but there is no option as you talking about that we should choose option 5, there is no display like that so please help me
tarafından
Yorum Ekle
so im not sure that will work all the time it might be a simple fix of haveing it refurnished that is what im gonna do but let me know how that works
Puan 0
1 Yorum:
Thanks man!, it worked out you are the BEST❤
Love from Nigeria ??
tarafından
Yorum Ekle
Yanıtını ekle
vatoloco sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 30
Son 7 gün: 251
Son 30 gün: 1,364
Her zaman: 85,562
