Ana içeriğe geç
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
464 Soru Tümünü görüntüle
How to fix the blinking question mark folder?
I have this blinking question mark folder on my screen.
I looked for the solutions and I found that it's not the hard drive problem, but the cable that connects the hard drive...
So I tried to order a new cable and replace it, but I just found that MacBook Air 2013 (A1446) does not have the connecting cable... ;(
It has a solid(?) or fixed SSD adapter instead.
So is there any way that I can replace the adapter (?) of SSD? (not SSD board itself)
Or... Is there any other solution?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
A little bit of knowledge can be dangerous. The likelihood of this being a bad SSD is low and there is no cable the SSD connection is integrated into the logic board. Most likely is that you have a corrupted system folder. Reboot the machine holding down the option key and select the repair partition. Run Disk Utilities on the drive and see if you can repair it. That failing you can then try a reinstall of the system.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
En Yararlı Yanıt
The blinking question mark usually happens with faulty drive in this series.
Inspect your SSD connector to logic board for corrosion or damage. Most likely your SSD drive is gone.
You'll need to test it with an Apple SSD to USB adapter and connect it another Mac, or buy new SSD.
MacBook Air 2013 SSD's are PCIe based. Proprietary to Apple as explained here:
EveryMac - MacBook Air Q&A
MacBook Air 13" Mid 2013 Solid-State Drive Replacement
Puan 3
2 Yorum:
OWC offers the required SSD and the carrier to hold it: SSD Flash Storage Options For MacBook Air 13" 2013 - 2017
tarafından
Thanks a lot for the answer
tarafından
Yorum Ekle
Yanıtını ekle
정찬경 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 7,529
