Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
589 Soru Tümünü görüntüle
All of a sudden it shuts down
My 1st gen iPad Air shuts down at indefinite moments and will not open back unless I press simultaneously both the shutdown and the start button. Happens several times, is there something that can be done to fix it?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
OPEN ALL THE TABS
RAM Upgrade Kits for Mac
Kit Satın Al
Enough RAM
For All The Tabs
Kit Satın Al
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
This could be caused by several different things. Please let us know more about the history of the device.
My initial suspicion would be the battery. The device is now 4 years old and the battery could be at the end of it's life. To be certain, use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows). It will tell you what the health of the battery is. Anything less than 70% of design capacity will require replacement.
If the battery is fine, then it would really depend on what the iPad has gone through in the past. Was it dropped or damaged (dented corners), came into contact with water or previously repaired. These can cause logic board issues.
The other thing that I would try is a full DFU Restore. This will completely over-write iOS and all data. It will be factory fresh, so to speak. That would eliminate any potential software/data corruption issues.
Bu yanıt yardımcı oldu mu?
Puan 5
Yorumlar:
Thanks Minho ill take the steps one by one, btw what is a DFU Restore and how is it done?
Regarding the Coconut Battery app, is that supposed to be for iOS9? I can't find it in the App Store!
tarafından
coconutBattery is an OSX application.
You can find more on DFU here.
tarafından
Also let me add that it doesn't just shut down, there are times that it closes and the Apple logo turns on and then will reboot. For example in this link
https://coconut-flavour.com/coconutbatte...
when I try to download the coconutBattery_3.6.3.zip file selecting "open with Viber" it makes my iPad reboot! Can this be explained by someway?
tarafından
Coconut battery is a Mac OS X application not a mobile app so it runs off a MacBook or iMac.
Battery life app on apple app store runs on iOS which means you can run it off your iPad.
3utools on the other hand is a windows application which you can run off a computer running Windows.
tarafından
Battery design capacity is close to 90% so i guess it shouldnt be the battery.
There are a few dented corners and yes prolly it has been dropped. So i guess i next step might be the DFU Restore.
Still id like to ask, is it normal when trying to download (the file i noted before) to reboot?
tarafından
5 daha fazla yorum göster
Yorum Ekle
This is the result of the Coconutbattery app on my iPad
does it look ok?
Puan 0
Yorumlar:
Your battery is fine. You want to look at the design capacity and charge cycles. Your battery can still hold ~93% of it's designed capacity. Anything above ~70% is ok but over 80% is good and over 90% is very good. The number of cycle counts is also important, especially if you buy something used. Anything under 750 - 1000 is good but every battery is different on that count.
tarafından
So what would be the next step? The DFU restore?
tarafından
Yorum Ekle
Yanıtını ekle
genik sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 77
Son 30 gün: 403
Her zaman: 15,139
