Ana içeriğe geç
The JBL Charge was released in 2012. It features Bluetooth and 3.5mm audio for a wide range of inputs. A high-capacity 6000mAh battery provides several hours of entertainment and can charge other devices with its built-in USB port. Available in Black, Green, Gray, and Blue.
27 Soru Tümünü görüntüle
My son's jbl charge got wet, I would like to try to fix it.
It actually fell into a hot tub. I would like to know how I can determine what component are bad. It will not power up or change . I have volt meters, to do any testing I might need to do. Or should I just replace the battery. Any advice that will help will be much appreciated.
Thank you
Dr. Carter
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@kimber1911 for now you do want to stop trying to charge it or to power it up. After all, this is a water damaged device and trying to do any of the aforementioned could be making it worse. Use these guides to disassemble it. Then clean every part with 90%+ isopropyl alcohol which includes cable connectors etc. Then once you cleaned it properly replace the battery and only then can you try to turn it on and perform more fault finding if it should still be needed.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thank for your help, I will give it a try.
tarafından
Yorum Ekle
Yanıtını ekle
Denis Carter sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 1,549
