Ana içeriğe geç
2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
265 Soru Tümünü görüntüle
A1425 Won't Power On After Keyboard Replacement
Hi, everyone! I recently picked up a Retina Macbook Pro 13" a1425 to fix up. When I got it, it would only power on when you plugged in the magsafe and the fans would run on high. Since it wouldn't respond to the keyboard, I assumed some liquid damage on the keyboard.
I purchased a replacement keyboard and just installed it. Now, it doesn't power on when you plug in a magsafe, but it also doesn't power on with the power button. The keyboard does appear to be working though because I can perform an SMC reset (which doesn't help). When the magsafe is plugged in, the light goes from green to amber. It will also go to amber if I unplug the battery.
Anybody have any ideas?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Update #3: after holding down the power button for ten seconds, then connecting magsafe, it turns on with fans on high like it did before I replaced the keyboard. There is currently no SSD so I connected an external Hd with Sierra on it. I was able to boot into it when I wasn't able to do this before the keyboard replacement. After logging in, there appears to be an x over the battery icon and it says battery not detected. The keyboard and trackpad all work fine so I am ruling those out now.
Anybody know how to fix this or does this mean I have to replace the battery?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Disconnect the keyboard ribbon cable and then use the power pads to start the system are you able to get it to startup that way? If you can carefully reseat the ribbon cable making sure it's squarely and fully inserted. I use a small strip of electicans tape which I fold over one end to make a pull to help in seating the cable.
Refer to this IFIXIT guide: MacBook Pro 13" Retina Display Late 2012 Logic Board Replacement jump down to Step28.
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
Thanks for your response. Where can I find the power on pads?
If the keyboard ribbon cable was seated improperly, though, I would have thought I couldn't do an SMC reset.
tarafından
Take a look here: A1278 Early-Late 2011
tarafından
Thx for the link but doesn't look like retina models are listed there.
tarafından
Sorry Jon,
I looked high & low to find my notes on where the pads are, sadly you have one of the models I haven't worked on. I also did a bit of digging online as well with no luck.
Hopefully some else can give us a clue were the pads are in this series.
tarafından
Yorum Ekle
Can you power up the system with the battery connector unplugged?
Puan 0
4 Yorum:
I tried unplugging the battery and plugging in the magsafe but it still does not turn on.
tarafından
Unplug the keyboard and trackpad and with the lid open plug in the magsafe. Same prompt to turn on as hitting the power pads.
tarafından
Update: After unplugging the trackpad and connecting to magsafe the fans start spinning but doesn't turn on. Also tried unplugging the trackpad and keyboard then plugging in magsafe and the same thing happens. Still doesn't boot up though.
tarafından
Update #2: tried reseating trackpad and keyboard cable. Now, when plugging magsafe in, fans spin but still doesn't turn on.
tarafından
Yorum Ekle
Yanıtını ekle
Jon Lewin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 1,752
