Ana içeriğe geç
Fix Your Stuff
Right to Repair
Parts & Tools
iPhone 6 screen popping out
The screen is popping out at where the volume and mute buttons are after a screen replacement.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorumlar:
My iPhone 6 screen has popped out to the left of my home button I hemnes help
tarafından
Faye Mine is like that only on the right. Something under my home button slid backwards and now the button wont work.
tarafından
Yorum Ekle
7 Cevap
Filtre ölçütü:
Seçilen Çözüm
Common issue with iPhone 6 aftermarket replacement screens.
Few things to check:
Make sure the frame is clean and not bent in any way, the corners or the iPhone housing as a whole.
If it's bent you should straighten it flat so that the screen can sit flush
Dents going inwards in the frame on the edges need to be bent back into place as well, especially at the corners of the frame where the screen sits on.
Other than that getting better quality screens (one with better screen frames that sit in properly and don't have the infamous gap near the vibrate switch / volume area).
Bu yanıt yardımcı oldu mu?
Puan 5
Yorumlar:
How would I go about trying to straighten the frame if it is bent
tarafından
Hi
One of the cause could be due to the phone battery as the battery heat up the paper wrapping around it expands to push out the screen
tarafından
Yorum Ekle
hii,
So, my iPhone 6's front top left corner of the screen appears to have "popped out" (Best way to phrase it)... I don't know whether I should go to the geniuses or try to pop it back myself... It appears to have popped out of the hook inside the phone, and if i jam it a little i can put it back in, but I'm afraid that it'll crack the screen. What should I do?
Thanks!
I didn't find the right solution from the Internet.
References: https://discussions.apple.com/thread/685...
web video marketing
Puan 0
Yorumlar:
get a pentalobe screw driver and remove the bottom screws. pry the screen up from the bottom and around the sides and then reinsert the screen and replace the screws.
tarafından
This comment by Henry Mang is the answer! you need to take the screws out next to the charging port with a P2 bit and then use a guitar pick to pry the rest of the screen off. Once off, insert the screen clips first and then press the rest of the screen back down along the edges to re attach to the adhesive. screw the 2 screws back in.
tarafından
Yorum Ekle
did not help at all because the screen is popped out
Puan 0
Yorum Ekle
i dropped my phone now it cracked and the screen popped out and it wont turn on HELP !!!!!
Puan 0
Yorumlar:
replace the screen
tarafından
Yorum Ekle
So my home button to my iphone 6 had an issue where the left side of it was stuck up and the right side of it was stuck down I fixed it but now my whole frame around the edges is popping out what should i do and we went to the store and they said it was the home button and it should pop back but it is the screen PLEASE HELP ME!!!!!!!!!!!!!!!
Puan 0
Yorum Ekle
I had same problem I went on eBay and bought the iPhone screen tape £1.95 worked a great
Puan 0
Yorumlar:
My IPhone 6split open on the left side took it in to repair shop he checked they battery was good so he fixed it and charged me $15 it’s great now!
Why does it happen?
tarafından
Yorum Ekle
My dumb sister sat on my phone screen and it the top was already popping off then boom fat sister made it worse i’m so mad she will pay oh yes she will
Puan 0
Yorum Ekle
Yanıtını ekle
Haris sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 31
Son 7 gün: 231
Son 30 gün: 1,108
Her zaman: 59,417
