Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
Screen does not turn on at all (tried replacing charging port as well)
I had replaced my sister's battery recently as it was starting to lose its charge very quickly. However, in a month or so, she comes back with a broken phone that does not turn on or is recognizable to itunes either.
She told me she had used a portable fan that plugs into the bottom of the phone (a cheap chinese brand I think) which I speculated is what caused the damage to the phone. What do you guys think? Or, it's just coincidence and happened to died right after.
But anyways, so I thought it was the charging port that broke. So I replaced that, and still no luck. Also, tried hard resetting as well. If you guys could give any ideas on this, that'd be incredible!
Thanks,
Robert
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
You're probably right. Cheap peripherals can draw too much current or cause voltage spikes that damage the charging circuit (Tristar).
This will have to be repaired by a shop that does micro-soldering work.
Bu yanıt yardımcı oldu mu?
Puan 3
5 Yorum:
Thank you for the response. How much do you think it would cost to repair that?
tarafından
Dealing with a reputable micro-solderer will cost you about $100 - $150. Some may charge more and some less.
There are a few reputable micro-solderers who frequent this forum or you can search Google. You can check out my profile if you'd like, at the very least it will serve as a data point
tarafından
@mayer @oldturkey03 not sure if this is okay...but answering a direct question. Let me know.
tarafından
Robert Actually this is just the type of repair that Minho specializes in. @refectio You're fine with me, you didn't recommend yourself or post your web link (which is in your profile), right?
tarafından
@refectio @mayer looks good to me as well.
tarafından
Yorum Ekle
Have you checked voltage on the battery? Maybe the new battery was junk and died already, especially if it was an ebay part. Use a multi meter on the outer pins of the battery connector. Report back what you find.
Puan 1
1 Yorum:
Good point !
tarafından
Yorum Ekle
check the FPC socket, it is connection trouble
Puan 0
Yorum Ekle
Yanıtını ekle
robert7kim7 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 73
