Ana içeriğe geç
Repair guides and support for vehicles manufactured by Hyundai Motor Company.
164 Soru Tümünü görüntüle
My front bumper is coming loose
I recently bout a used 2015 Hyundai Accent. The dealer pointed out that the front bumper was coming loose, and that it would be repaired. When I picked it up, he said that his guy had put a clip on it to fix it, and it did look repaired. Now it is loose again, and I am afraid that if it rubs up against something, it may get worse.
Before I go through the hassle of trying to get the dealer to repair the problem again, how could I fix the problem myself. It is on the passenger side, and the plastic separates for about 7 inches.
Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
gatewaynomad post some images of your loose bumper so we can see what you see. Use this guide Adding images to an existing question for that. Most likely it is your bumper cover that is coming off. This from the manual:
  • Loosen the radiator upper cover mounting bolts and clips.
  • Remove the mounting clips.
  • After loosening the front bumper side’s mounting screw, then disconnect the side’s.
  • Push the lock pin, disconnect the fog lamp connector (A).
  • Remove the front bumper.
  • Installation is the reverse of removal
Bu yanıt yardımcı oldu mu?
Puan 1
Yorumlar:
That is exactly what I wanted, thank you!
tarafından
Yorum Ekle
My left side bumper is also apart sticking out looks like missing a clip or broke clip.
Puan 0
Yorumlar:
Follow the same procedure listed above if you have the same car.
tarafından
Yorum Ekle
Yanıtını ekle
gatewaynomad sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 10,268
