Ana içeriğe geç
Bu yazıcı, C4780 modeline benzer. (Bazen arızalanabilen) kablosuz donanımdan yoksundur ve ağ üzerinden yazdırma için yalnızca kablolu olarak bağlanabilir.
Why won't it print
Why isn't my HP Photosmart C4740 (Printer, Scanner & Copier) not printing?
It has a new black cartridge and half full color cartridge. The 1st print came out light blue/grey even though I chose black print. Now it acts like it's printing but paper comes out blank.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Take the cartridges out & clean the contacts with Q tips. Have your Q tip damp but not over-soaked with water. Then dry the cartridges with the dry end of a Q tip and then with a soft cloth. I used tap water, and after drying went over with a hair dryer just to make sure. It worked.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
Carefully clean the tank inkjets using a soft cloth and isopropyl alcohol. Often the jets can get clogged if left in. If you don't print that much store the cartridges in the cases provided.
If that fails you'll likely need new cartridges.
Puan 2
Yorum Ekle
Yanıtını ekle
Tracy Klein sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 615
