Headset cuts in and out when plugged into Handset jack
When we plug our headset into the handset jack of our landline portable phone,
it cuts in and out constantly. You might find a sweet spot where it stops if you keep wiggling the headset jack around in the handset (female) jack but the slightest movement will make it cut in and out again. For awhile I could find the sweet spot and secure the spot using a rubber band but even that rarely works now. Is there a way to repair or replace the jack in the handset?
Bu iyi bir soru mu?
My phone says check tel line, what can be the problem
Help tarafından
I can not receive or make calls
Help tarafından
