iPhone Replaced Battery now sleep/wake button and video mic won’t work
Recently replaced my iPhone 6 battery. Now the sleep/wake button won’t work as well as faint-scratchy/no sound recorded on videos.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Ok, I should've just posted my answer earlier. So you've damaged some stuff while doing your repair. The power button, which is connected to the volume/mute, which you'll have to remove the battery and the logic board. It's a pretty big repair. Youve also likely damaged the front camera flex assembly. Not that big of a job. I mean you should check that and make sure you properly seated the connections. But likely you'll have to order new a new one
iPhone 6 Power Button Cable Assembly Replacement
iPhone 6 Ön Kamera ve Sensör Kablosu Değişimi
Ürün
$19.99
Ürün
$9.99
Kılavuz
Zorluk:
Zor
1 - 2 hours
Kılavuz
Zorluk:
Orta
30 minutes - 1 hour
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 211
2 Yorum
Does you volume/mute switch work?
iMedic tarafından
Yes it works.
eric collins tarafından
