Ana içeriğe geç
Caller on other end can’t hear me
I can make calls and hear fine
I’ve recorded a video and I hear the sound in the playback
I’ve recorded myself in voice memo sounds loud and clear I can even FaceTime and they can hear me fine but a normal call and they can’t hear me at all I hear myself echo
Please help me
Bu iyi bir soru mu?
Puan 10
10 Yorum
Very bad when u can communicate on time
tarafından
When I make phone calls the person on the other end can't hear me talking I've already done a factory reset it still doesn't work I'm looking forward to be hearing from you as soon as possible to take care of this problem I'm having trouble with your friend Rose Yost..
tarafından
I've been trying and trying to tell you when I make outside calls the person on the other end can't hear me talking i don't know why I just need some help with this problem I'm having trouble with your friend Rose Yost..
tarafından
I can watch movie from YouTube by using earphn but when I call to someone my voice couldn't hear to other
tarafından
Iam using iPhone 6 I can hear the caller clearly but the caller can’t hear me
tarafından
5 tane daha yorum göster
Yorum Ekle
7 Cevap
Filtre ölçütü:
Seçilen Çözüm
Parts
iPhone 6 Plus Lightning Connector and Headphone Jack
Labor
iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement
iPhone 6 Plus Lightning Connector and Headphone Jack Görseli
Ürün
$29.99
Bu yanıt yardımcı oldu mu?
Puan 5
1 Yorum:
I had two different new ones changed still no luck smh any other ideas I’m lost without any other answers
tarafından
Yorum Ekle
The iPhone 6Plus has 3 microphones
1. In the earpiece which is used for voice memos and face time calls
2. One on the back of the phone which records audio for videos
3. On on the bottom of the phone next to the headphone jack to make calls.
The fix. Make sure those holes on the bottom of the phone are clean, if they are and you still have the same problem, replace the charger port on the bottom of the phone. The part is fairly cheep.
Puan 4
1 Yorum:
I had it changed twice still no luck smh
Any other ideas
tarafından
Yorum Ekle
It is going to be one of three things...Hardware, Software or your network.
It sounds as if you have already attempted the hardware fix, just make sure you have installed the Mic portion of your port assembly correctly and may even try to use a very small piece of cotton (Like from a Q-Tip) and pack it around the mic.
It could be a software issue, you could back up your data on Itunes, restore it and see if that helps
or...call your network provider and explain the issue. they may (or may not) be able to help depending on who you get on the line and how willing they are to try and help.
I am not talking from experience, as I have not had this issue...but did research it a bit to try and offer some help. If you do figure it out, please post back what worked for you to offer a fix for others that may have your same issue.
Good Luck!
Puan 3
3 Yorum:
We’ll update
The uga dawgs Are eating gator meat today
But I did go ahead and get a new phone
I couldn’t deal any longer
I had changed the mic 3 times ,restored even reset etc and also did a network update nothing help someone stated iOS 11 bugs
tarafından
thank you @teetopp it helps for me
tarafından
I have tracphone iphone 6sPlus BYOP and when I activated the phone was ok then but when I updated to ios12 the problem came back
tarafından
Yorum Ekle
Assuming there are no other variables like water damage, drops, etc I would agree that a reset is the the first step if you have indeed replaced the hardware already. You can try resetting some of the other settings in General>Reset>(options) also. It may be related to the newer update if there is a software conflict with one or more apps that are installed. The iOS 11 updates were riddled with bugs for many devices.
Puan 2
Yorum Ekle
I found a simple fix I had the plastic cover the protector on top of the phone covering the speaker make sure the hole at the top is not covered with your protective covering Once I remove the plastic and cut it down to just fit only the screen I was able to hear magnificently
Puan 0
1 Yorum:
cecilia it could be hole on the down side :) because the other person is not hearing the voice.....
tarafından
Yorum Ekle
i have the same problem, previously never been problem like this when im using android..hmmm
Puan 0
Yorum Ekle
This is a Apple/carrier issue. the iPhone6 for some reason is not passing the voice on the AT&T network. I attached the phone to the bluetooth in my car, so none of the phone’s mics are in play. I can hear them, but they can’t hear me. I took the phone to the Apple store, and their Genius basically tried to have me spend $299 to upgrade the phone. I think I will upgrade the phone to an Android.
Puan 0
Yorum Ekle
Yanıtını ekle
Zunichi7@gmail.com sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 60
Her zaman: 187,612
