Ana içeriğe geç
The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
313 Soru Tümünü görüntüle
MacBook Air heating up on the right side of the keyboard?
MacBook Air starts heating up and down on the right side of the keyboard, near the power and volume buttons, and it consuming battery faster, it lasting about 2 hours. I did all the processes recommended by Apple, and the diagnostic was an issue on the thunderbolt hardware. I installed TG Pro and it showing this temperatures:
Please, help me !
Thanks
Update (10/26/2017)
Thanks for answer me.
I don't think this heating is fine, because it's burning my fingers... I have never felt these temperature before.
I forgot to say that it's overheating while sleeping, and when it's closed, it heats the screen (top right) and when I "wake up" it, no battery at all.
I already reinstall the operating system, doesn't work.
Does this temperature could ruin my logic board?
Thanks again.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
3 Yorum
The heat will not damage the logic board. It is fairly normal. Download Macs Fan Control and see what CPU core 1 and 2 are reading. Anything below 92*C is fine.
tarafından
I have exactly the same problem. And I really don't think the heat is from the cpu. CPU temperatures are pretty low (mid 40s to Mid 50s) compared to low 70s in the “thunderbolt proximity” and “air drop proximity”
tarafından
Hi Ana, I also got this problem with my Macbook Air.
Exactly on the right side near the thunderbolt port. Which is strange because it always heated up on the left side, I believe it is the side that that the cpu it's located. Today, the left side it's not that heated, but the right side is.
Did you manage to solve this problem?
Att
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Those temps are fine. Pretty much all that heat is from the CPU doing something intensive and does not indicate a hardware issue.
Usually when you have a thunderbolt issue it holds down several main power rails making the machine unusable.... So I don't think you have a thunderbolt issue... OSX driver issue? Maybe.
I would back up your stuff and reinstall the operating system. The system has several sensors and will shut off if it gets too hot. 78*C is well within safe limits.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I have the same issue. Reinstall doesn’t work. safe mode doesn’t work. months of trying software-related things don’t work.
I think there is a hardware issue, a short or something causing that heat. I don’t use the ports on the right side so they shouldn’t be making any heat. It’s frustrating.
I am about to send it in for a diagnosis.
Puan 0
2 Yorum:
Hi, have you used your thunderbolt and it's functioning well? Like the dongle with HDMI, ou ethernet? Because mine doesn't work properly and maybe it's the problem with it.
tarafından
Yorum Ekle
Yanıtını ekle
Ana CArolina sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 3,319
