Ana içeriğe geç
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
Why can't my Dell Inspiron 1525 charge the replacement battery?
Battery doesn't hold any charge.
Bu iyi bir soru mu?
Puan 1
3 Yorum
Is it a new battery that you're trying to use?
tarafından
No, it's an old replacement battery and the electrical cord is used as well. Has been worked on prior times, not me. Trying to save the laptop since it's my only backup and my Mac doesn't have microsoft cause I can't afford to buy the approved programs.
tarafından
Use this : Dell AC Adapter LA90PM130
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Ok so what I would do is look for a replacement battery on Amazon, like this one:
Dell Inspiron 1525 Battery - Amazon
Try using that, and it should work just fine.
- Jasen
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
if Ur useing a new battery then u probably need to replace the charger port
Puan 0
Yorum Ekle
I have replace the battery & also replace the charger port , then same problem could not charging the battery…..
now what can I do…..?
Puan 0
Yorum Ekle
Yanıtını ekle
Maria sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 447
