Ana içeriğe geç
iPad Mini 4— A1538 modelinin Wi-Fi versiyonu için kılavuzlar. 9 Eylül 2015'te duyurulan iPad Mini 4, iPad Mini 3 modelinin yenisidir.
97 Soru Tümünü görüntüle
Question about home button replacement
So, I have this iPad mini 4 which the Touch ID works, but the home button doesn’t. Is there a way to just replace the home button clicking part?
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Have you recently replaced the screen or have had it opened before the problem?
Yes, you can replace the home button to get it working again or you can open it to make sure it is making proper contact with the pads that make the physical connection. Here is a post that describes the issue a bit better:
iPad Mini Home Button Not Working After Digitizer Replacement
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Yes, I have done a screen replacement before. Well during that time, a rubber thing was thorn apart and I just left it in my drawer. How would I go about just replacing the home button part instead of the whole Touch ID + home button? Would the Touch ID still work?
tarafından
Yorum Ekle
Yanıtını ekle
Koguma6969 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 1,507
