Ana içeriğe geç
Device doesn't charge after display replacement.
Hey, I needed to replace the display of an S8 Plus. Unfortunately it doesn't charge after the replacement. The temperature is too low. I tried a new battery and the phone starts but still it won't charge and I get the same error that device temperature is too low. Any ideas?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi. I had the same problem for 2 s8 and s8+. Try to assemble the whole phones, including screws, without back cover and put it in charge. It worked for me, i hope it will do it for you as well.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Thank you! It worked for me too!
tarafından
Thanks was helping to save my day. you really have to assemble before charging . superb
tarafından
Yorum Ekle
En Yararlı Yanıt
Charging port is most likely faulty. I take it you used a replacement display assembly which included LCD with frame and charging port with it?
I'm not 100% sure about this but the charging port model label mismatch from the phone model can cause issues e.g SM-G920I with SM-G920F for example.
Puan 2
1 Yorum:
No I had to take the original charging port, but I will try another one and tell you if it worked! Thank you :)
tarafından
Yorum Ekle
If you have a Samsung Galaxy S8 or S8+, there’s no foolproof way to prevent it from damage.  Just get it serviced from the professional. That’s it !
Because doing all things on your own cannot get it run in the proper way.
Regards,
Gadget Genie
Puan 1
Yorum Ekle
Check to see if you have the NFC installed
Puan 0
Yorum Ekle
Yanıtını ekle
elreparero sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 3,305
