Ana içeriğe geç
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
755 Soru Tümünü görüntüle
replaced screen and battery
replaced battery and screen, followed the manual and checked the connections, unit was charged and it does not work.
Update
The screen got damaged in the car. I figured that the unit is 5 yrs old so as long as I am opening the unit might as well replace the battery. I charged the battery but did not try connecting to Itunes.
Bu iyi bir soru mu?
Puan -1
Yorumlar:
okay so what does it do? Anything, blank screen, does itunes recognize it? why did you replace those items?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
bkan209, I would open it up again and triple check the connections. the display connector has a tendency in going in somewhat crooked and can be difficult to manipulate. The battery connector is just as tricky at times. Make sure the tab is up and that you insert the cable deep enough, then replace the locking tab by pushing it down. I would definitely try to connect it to itunes or at least you computer so as to see if the computer recognizes it. You may not see it because of your display. Give it a try and let us know.
Bu yanıt yardımcı oldu mu?
Puan 5
Yorum Ekle
Before you open it up, did you try turning it on while charging? That could narrow the problem down to being just the battery that isn't connected proberly.
I'v made a sketch of the locking mechanism:
http://shadowofcertainty.blogspot.com/20...
good luck.
Puan 1
Yorumlar:
Pretty good representation. I also do not like the idea of using the opening tool to lift the clip, broke the connector of twice that way :-)
tarafından
thanks, I used a wooden stick that I had fitted with a knife. But maybe it should read "careful" somewhere.
tarafından
I now use a paperclip bend into an L-shape and place it under the clip pulling up and that minimizes the sideways prying force. None broken since :-)
tarafından
good tip, tx
tarafından
Yorum Ekle
Yanıtını ekle
bkan209 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 645
