Ana içeriğe geç
The OontZ Angle 3 is a high quality, lightweight speaker made by Cambridge SoundWorks.
Why won't the Oontz Angle 3 speaker connect with PC Bluetooth?
The connection worked previously, I have no idea what has changed.
The PC sees the speaker, but the speaker doesn't play.
I tested the PC with AUX cable which works, I am also able to connect the speaker through Bluetooth on my phone.
I have checked all my PC settings and have no idea what else to look.
Help!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
This happened to me, too, recently. Just after updating my PC, the Oontz Angle 3 would only be recognized as "Bluetooth Headset" and would fail to connect.
I have obviously removed the Oontz Angle Device 3 and tried to reconnect it.
I have also deleted/reinstalled any/all Bluetooth drivers on my computer.
The Oontz connects perfectly well on my iPhone, however.
What is going on?
tarafından
I still don't know the reason, but it worked for me when I uninstaled the speaker and installed it again. It happened to me a few times the Bluetooth connection didn't work without this "manual reset". So, go to devices, installations, and remove and then again add the speaker. I hope this helps you too!
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
In my case, the computer was able to identify the speaker but it would not connect, giving a message that the device was not responding. After trying a number of other possible fixes, such as deleting it from the computer memory, rebooting the computer, turning off the firewall, I turned off the speaker and even disconnected it from the USB cable. I let it sit, powered down, for about 3 minutes, and then restarted the process. It connected without a problem.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Kristina Bogataj sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 3,563
