Ana içeriğe geç
Üçüncü nesil Kia Rio, 1 Mart 2011'de Cenevre Otomobil Fuarı'nda tanıtıldı ve yine Hyundai Accent temel alınarak geliştirildi.
Vehicle won't crank over
Vehicle won't crank over. I've replaced the crankshaft sensor, checked the alternator, battery, starter, coil packs, and replaced the spark plugs. And replaced the fuel pump. Just won't crank over. Any suggestions
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If you have a no crank situation and you have a good starter for sure then look for possible wiring issues . Look closely at the grounds. Check for engine codes as well . When you attempt to crank the car do you loose power to lights check the voltage at the battery as you attempt to crank . If you loose all voltage it could be a week cell in the battery that only shows up under draw conditions . Hope this helps
Bu yanıt yardımcı oldu mu?
Puan 5
1 Yorum:
Did you find out what was wrong? Im having the same issue with a Kia Rio 2011
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Royce J Daniels sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 6,363
