@freshstylez
Hot air reflow station:
For a quality station, look at Hakko Stations that have the Hot Tweezers and Micro Pencil. Expensive? Yes, but when working with Iphones and other electronics, cheaper stations will cook your boards. (I speak from experience). I bought a cheap station due to cost and it cost me more in damage.
With that being said, you can choose a cheaper station like the Yihua 853D (The one I started with) for about $80 and no Hot Tweezers for Changing Caps and filters, etc...but again, the drawback is not worth it.
Mini Hot Tweezers are fantastic! You are not heating up the whole board causing bridges and Cold solder joints on other areas of the board and are great for micro jumpers too.
If you are just wanting practice on a budget, it works fine... but if you are working on boards that are "Keepers" I wouldn't risk it.
As for PCB holder on a 6 or 6s, I like: https://www.amazon.com/gp/product/B07333...
It helps with a place for IC Chips for reballing but doesn't work with other boards like the 6 plus, 6s plus, etc... In that case, I use : https://www.amazon.com/gp/product/B01MQN...
Find a descent Ultrasinic cleaner and some Branson EC for cleaning the boards, 99% Iso Alcohol, a DC Power Supply and cables, Solder mask and UV light, a stencil kit for reballing and the basics...Flux, Solder, Solder paste (or balls), Wick, Kapton Tape, Silicone Pad, Tweezers, Xacto set, Screw driver set, Spudgers, and a Microscope....and some donor boards to practice with and to have some spare parts :)
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
5
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
1 Yorum
@freshstylez sounds like a case for the guru @refectio and @teetopp
oldturkey03 tarafından
