Ana içeriğe geç
Repair and support for the third generation of the Flip portable speaker by JBL.
My JBL Flip 4 won't power on
To be clear I have a JBL Flip 4, but the flip 4 wasn't listed in the categories...
When I plug it in, it shows that the battery is charged, all lights are white, and the last one blinks to show that it is charging that last little bit. But this is the only sign of life. I've tried holding the power button for 30 seconds (a recommended re-set technique), I've tried powering it while plugged in and while not plugged in. I plugged it into the wall, into my laptop- same thing every time. I tried a "fix" on this site that said to plug it in, and immediately remove the charge chord, and press the Bluetooth + button, and the Play button at the same time. But this is supposed to power down the speaker, my problem being that it never turns on.
my speaker is less than 6 mo old.
Any help would be great!!!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
5 Yorum
I have the same problem
tarafından
I also have the same problem!
tarafından
I also have the same problem.....my speaker is also 6 mos. old
tarafından
Same problem
tarafından
Same problem with my flip5. I had my first one stolen and now this one isn't even three months old and it will not boot up. I hope some of these kooky fixes work
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You have tried the wrong methods, the actual method is push the connect button and the volume plus button simultaneously until it turns out when it is charging.
Bu yanıt yardımcı oldu mu?
Puan 7
6 Yorum:
Thank you so much!!!!
tarafından
Thanks, helped with the first try.
tarafından
Didn’t work for me :(
tarafından
I did your actual method while plugged in, held the buttons until the lights went out....I still won't power up. Does it need to be recharged?
tarafından
Thanks this worked fro me!!!
tarafından
1 tane daha yorum göster
Yorum Ekle
It didn’t work for me……Only the white and charging dots light up when I plug it in….then when I push the connect button an d volume up button, the other light left of the power button turns on,then almost immediately both go out.  I have to unplug from the wall, then plug in again, to repeat this process.  Will not power up.
Puan 0
1 Yorum:
Mine does that exact same thing .did you ever figure it out . help plse
tarafından
Yorum Ekle
With my JBL Flip 4, I had no light or power turning on. It turned out to be the internal connection. to fix this you need to take it apart somewhat and just push the connection in a little. took about 10 mins. Mine turned on right away. this youtube video walks you through it. https://www.youtube.com/watch?v=_ygjoN3I...
Puan 0
Yorum Ekle
Yanıtını ekle
rion sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 38
Her zaman: 20,096
