Ana içeriğe geç
Announced in August 2017, the Galaxy Note8 is the successor to the recalled Galaxy Note7. The Note8 was made available to the public for purchase in September of 2017.
148 Soru Tümünü görüntüle
My battery died to 0% and won't charge now, wired nor wireless.
I was using my phone like normal and the battery went to 0 and the phone shut down now it won't charge Wireless or wired. 2x note8's in the house with 4x wired chargers and 2x wireless and all confirmed working with other note8. Plugging them in and holding power + volumn ^ and √ and bixby and every combination doesn't work and no water damage but I did drop once from waist height (shame my butter fingers and it was only a week old) but that doesn't constitute this because a whole month gone by of use from it before this...
Bu iyi bir soru mu?
Puan 4
1 Yorum
I want to add that even after bringing it back to life and a new firmware update, One night connected at 17% life (because I just didn't ever let it go 0 again) I went to sleep and woke up to a completely dead phone again. After repeating the steps and bringing it back to life once more this time it actually gave me an error log saying the "phone is too cold to charge"! Like an overheating message but I didn't think it was possible! To cold?! Wow...hopefully the battery just had a defective integrated temp sensor...but that's just a guess and I recommend just sending it to Samsung and back up your data. I was going to get a new battery to test but my luck has been very bad this week with my bmw suspension support braking while on the freeway going 65mph and 4 1/2 rolls later my note 8 is somewhere on that freeway getting smashed to bits...at least I didn't die...but then the next night my truck got burglarized with my ifixit protech toolkit and iPhone parts stolen....so yeah FML.
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
So I actually fixed this myself. Out of desperation and exhausting every other option I finally just took the back glass off with the help of the teardown guide and "defibulated" the battery back to life.
So the process went like this; after actually getting to the battery, cut an old USB cord and splice it down to the red and black wires leaving a few millimeters exposed and get an old USB charger, I used an old Samsung I had, A NEWER CHARGER INCLUDING THE NOTE 8 CHARGER WILL NOT WORK ex." fast chargers, QC 2.0 and QC 3.0+" ect. The ribbon cord leading off the battery are labeled "1 2 and 7 8" on the other side says which pair are + & - and very carefully hold the red to + and black to - for about a minute. Reconnect battery and plug the actual Note 8 charger in and Viola! You should be charging!!!! My back glass was already broke and is only $12 to replace. But I feel like if it wasn't cracked I could have done without damage...other then the paint coming off the inside a little bit.
Bu yanıt yardımcı oldu mu?
Puan 6
3 Yorum:
I tried what you said and it worked perfectly. the first time i tried it i held it there for about a minuet and the phone came to life briefly, unfortunately not long enough to get a charge. Next i just held it there for about 2-3 min and then plugged it in, worked like a charm! thanks for the advice!
tarafından
Worked like a charm.
I sanded the ribbon cable to strip the protective coating covering the copper a little because holding the charge wire to the tiny connector was near impossible.
tarafından
If the Note 8 goes to 0% you need to connect the original charger and original cable. Any other cable won't work, it has to be the white one that came with your phone. However, a different charger sometimes works with the original white cable.
tarafından
Yorum Ekle
Hold the volume down button and the power on button for 10-15 seconds and that will simulate a battery out(removal) and force a reset and your phone should start charging again
Puan 1
3 Yorum:
I tried that already obviously I would think to try that and everyone else looking at this thread.
tarafından
ultra 22 doing same thing and ya can;t hold buttons phone is completely dead
tarafından
I tried this and it worked guess I just wasn't holding it long enough..
tarafından
Yorum Ekle
@Tim Castilla  Thank you. Charging the battery directly with USB charger works. Rather than connecting to the pin of the connector, I just removed the insulation of the flex cable with the tips of tweezers. then used two tweezers to hold the black/red wires to make the connection to the exposed copper surface on the flex cable. You may want to patch the insulation with a small piece of electric tape. I just leave it as is.
Oh, one more thing, if you turn on the phone without the wireless charging pad restored, you will get the error of low batter temperature, with a red led light and a yellow triangle with ! sign inside. Just restore the wireless charging pad.
Puan 1
1 Yorum:
I mean get the error message[low batter temperature] while charging
tarafından
Yorum Ekle
It is a issue happend in some Samsung Galaxy Note 8 users, maybe you can try these ways:4 Ways to fix Samsung Galaxy Note 8 battery drop to 0% not charge issue
Puan 0
Yorum Ekle
Yanıtını ekle
Tim Castilla sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 67
Son 30 gün: 388
Her zaman: 65,230
