Ana içeriğe geç
The HTC 7 Surround is a smartphone created by HTC running on the Windows Phone operating system.
7 Soru Tümünü görüntüle
Device will not go past 'htc' boot screen
Bu iyi bir soru mu?
Puan 48
13 Yorum
Did you try Jail-breaking it or something, before it failed?
If it's still under warranty, bring it to the MFG to get repaired or replaced.
If not these guys fixed my HTC HD2 a few months back.
If fixing it through USB doesn't work, you have to take it apart...
They had to take the Circuit Board out, and reprogram it.
The cool thing is they didn't erase my stuff.. It was all there afterwards.
tarafından
how much did it cost to get it fixed? also what's the number to call to get it fixed?
tarafından
I can't tell you how much. I'm not allowed.
You ask them but I think they need to see it first before they give you a quote. 800 - 691 - 8351 epic data
tarafından
my HTC Model ADR 6410L Droid incredible software dead ,now how can it recoverable.
tarafından
I had this problem and tries all sorts! in the end all i had to do is take out my mirco sd card... hope this might help!
tarafından
8 tane daha yorum göster
Yorum Ekle
7 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sounds like a corrupt system. Since it's can't be more than four months old, I'd take it in for warranty work. No reason to risk voiding your warranty by messing with it.
Bu yanıt yardımcı oldu mu?
Puan 5
Yorum Ekle
I would try a hard reset just in case this should work before you take it back to the store :-)
Try to reset your phone by
Press the Vol up and Vol Down keys while you power your phone on it should give you the prompt to reset your phone.
Remember that this WILL ERASE all your data. Hope this helps you out. But do not start looking any further, since your phone should still be covered under warranty. Good Luck.
Puan 3
8 Yorum:
I did this to my phone a million times and my phone still won't work. I have an HTC desire 510 BTW.
tarafından
I tried it too and it didn't work either
tarafından
Same. I have the HTC desire 510 and I did it a ba-jillion Times and nothing's different
tarafından
My HTC m8 can not boot to home screen please help me solve this proble
tarafından
HTC desire 510 repeatly resets its self after boot screen how to fix this?
tarafından
3 tane daha yorum göster
Yorum Ekle
hey anti,
you are basically at a bootloader screen, what you have to do next is connect the phone through usb to ur computer/laptop and wait for it to recognize the phone and install its drivers, once the drivers are installed u will see that in place of serial, it will say "usb", at this point, go to
http://forum.xda-developers.com/showthre...
and follow the instructions, there are 2 roms to download, and u have to follow the steps
1. download both files
2. open up the romupdateutility.exe from the first downloaded zip file and run it, follow the steps on screen, once it finishes flashing, it will show an error, ignore it and exit, ur fone will reboot and come back to the same tri color screen as before, then wait to see it say "usb" again, then you open the romupdateutility.exe from the second zip file that you downloaded and run the same procedure and wait
once u r done, ur phone will hopefully work, hope this helps.
Puan 2
3 Yorum:
And if the above mentioned procedure doesnt work, the only way is to void the warranty, open up ur phone and replace the micro sdhc card present inside as mentioned in one of the above replies
tarafından
hi, good advise. but i am stuck becouse when i tried to down the two ROMs, i was hit with a 'NOT FILE FOUND TO DOWNLOAED' kindly advise wat to do next or plan B???
tarafından
Would if it wont reconize it?
tarafından
Yorum Ekle
you have to wait dude. it looks like it is hung but it takes a long time then suddenly it loads then it is normal after that. dont restart it over and over trying to get it to boot after reset, the reset is not done yet.
Puan 2
Yorum Ekle
Hi, I had the problem, was stuck on screen with 3 skateboarding andys, tried shutting power down using the options on screen, all it did was shut down , and I restarted , back to same screen. I shut down again using the power and volume keys, with the power cable plugged in, phone was showing locked, on top of screen. I restarted using power button, after a few long minutes everything was back on .
Puan 0
Yorum Ekle
buy a new phone....// preferably a SAMSUNG or iphone
Puan 0
Yorum Ekle
Well its a complicated process to fully recover recovery after you see dead android guy will have to press and hold the power and volume down keys when the screen goes COMPLETELY DARK at “BIOS like screen” will appears elect (using the vol up/dwn) keys select boot to google screen, your android should be bootng normally again. If not contact support and have them “hard wipe
Puan 0
Yorum Ekle
Yanıtını ekle
Otto sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 29
Her zaman: 134,655
