Ana içeriğe geç
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
516 Soru Tümünü görüntüle
Was cleaning my screen using Colin and water got under screen
Today as usual was cleaning my macbook's screen by spraying Colin(screen cleaner) then wiping it off with microfibre cloth. Suddenly I begin to notice water under my screen and don't know how it got there. Laptop is working fine but the screen is damaged.
What should I do ..?
Going to apple centre is expensive
Can I dry out the water by myself and if yes then how .?
Bu iyi bir soru mu?
Puan 0
2 Comments
Thanks
But using hairdryer doesn't seem to help.
Any other idea .?
tarafından
Okay. Either way, apple or fixing it yourself will be expensive
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Using a hair dryer at low heat should speed up the evaporation process. Just don’t cook your display and make sure the system is fully off!
I never recommend spraying anything directly onto the system! Wet a paper towel or microfiber cloth with the cleaner then wipe the area you are trying to clean.
I know this will sound silly! I use baby wipes (unscented) to wipe the systems surfaces as they have enough ruffness to clean without scratching. For displays I use a diluted mixture of reagent quality isopropyl alcohol and distilled water (50%).
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Sriwas Narayanan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 49
Her zaman: 6,252
