The Motorola V325 is a clam shell phone, featuring VZ Navigator.
2 Soru Tümünü görüntüle
Screen Blank, Keys light up.
My V325 has not been used for years. We recently need another phone. We recharged the phone and it starts (keys light up) but the screen is blank. Can it be fixed? Is there a reset button or something?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The only thing that i know about the hard reset is to remove the battery and leave it out for a few minutes. To get into test mode do the following: Press CLR then 073887*. Turn on Test Mode and exit the menu back to your normal home screen. Then press CLR and then left softkey to activate FTS (Field Test).
To deactivate FTS and Test Mode, repeat the steps above, and turn Test Mode to off, then exit.
You may also have some LCD problem and may need to replace it. try the reset and take it from there. One step at a time.
Here is the SERVICE manual for you
Hope this helps....
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Ron sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 1
Son 30 Gün: 1
Her zaman: 627
