Ana içeriğe geç
Repair guides and support for gas and electric hot water tanks, boilers and household heat exchangers.
29 Soru Tümünü görüntüle
Thermostat failed, I replaced it ,its still over heating and tripping
The thermostat kept tripping so I replaced it. It fixed problem for couple months now it's tripping again. Should I replace the elements now or just one. It has upper and lower elements. It's a AO Smith that's only 4 years old is that normal.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @spydr03
Do you have a multimeter? well it is good to check those, there are tons instruction, which i think is very helpful to troubleshoot the water heater.
https://www.youtube.com/watch?v=SlyStHM9...
btw check that there are no water leaks and inspect the electrical cables.
just sharing:
my home is using rheem, and depending on the usage, the replacement i had done, is due to corrosion inside the heater which i need to replace the whole tank, so i guess the current one is about 7 years plus.
I was informed by my dad that the circuit breaker trips when turning on the switch of the heater, following the troubleshooting video on youtube, isolating, removing all power cables, eliminated the possible cause of issues one by one, until i notice there is actually a short on the power cable itself. open up the cable duct and to my horror, it melts. The contractor has used a wrong type of cable, which cannot handle high current, AWG ... replaced on a better and correct for the appliance and it works.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
new elements and breakers keep triping.
Puan 0
Yorum Ekle
Yanıtını ekle
greg sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 482
