Ana içeriğe geç
Ağustos 2003'te piyasaya sürüldü. Zamanının pahalı ama üst düzey bir dizüstü bilgisayarı.
Power won't stay on.
When i turn the power on the power light comes on then goes right off, what could be the problem.? I took out the ram and cpu and it still does the same thing. Can you help ? Tha same thing is happening with my Dell Inspiron 6000.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Plenty of things can cause the issue, and unfortunately most of this requires trial and error.
if your device is able to boot while plugged in, and battery removed, its simply a battery problem. however, you could also have a bad charge port, that is not giving current to the device, so it is not charging. You could have a problem with a board level component as well. some devices have a failsafe, that if it does not sense a fan, it will prevent itself from booting.
these are some of the more comon reasons devices wont start.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Greg Smith sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 271
