Trackpad and Keyboard Only Work at Login and After Loggin In
Hello! I have a 2013 MacBook Air 13” A1466 whose keyboard and trackpad only work once you get to login screen. Because of this, I am unable to boot into recovery mode, boot options, or hardware test with the internal keyboard. If I attach a bluetooth keyboard I am able to boot into these options. The board suffered a little bit of liquid damage and was transplanted into a new machine. Apart from not being able to use the startup boot options it seems fully functional.
I booted into AHT with external keyboard and it says there may be issue with trackpad and keyboard but they do work fine once you get to the login screen! I’ve tried SMC and PRAM reset to no avail.
Any help would be appreciated!
Bu iyi bir soru mu?
Which is your system? All of the A1466 models we really need to know what you have to answer.
Also where did you get the keyboard/trackpad you may have the wrong one. Can you give us the source and the P/N of what you bought.
Dan tarafından
It seems as though you didn’t read my post closely.
Jon Lewin tarafından
No, I did! Which is why I wanted to make sure. Your other post lists a 2014 so I wanted you to make sure what you have
So we have two different systems here.
Dan tarafından
Two different posts for two different systems for two separate issues, yes.
I got same issue and not found any solution yet. Thats crazy.
Claus tarafından
2 tane daha yorum göster
