Ana içeriğe geç
16 Şubat 2016'da piyasaya sürülen mavi, kırmızı veya beyaz renkli 11 inç Dell Inspiron 11-3162.
Why won't windows install
It says windows installation cannot proceed
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
Is that all it says? no error code or anything? What type of installation media are you trying to use? disk? Flash Drive? Or OS reset?
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
I will suggest you to check the BIOS settings provided below to see if you have similar settings. If not you may try these settings and then install the operating system.
  • Go to the BIOS screen by pressing F2 at the Dell logo 4-5 times.
  • Navigate to ‘Advanced Tab’ and select ‘Onboard Device Configuration’.
  • Set ‘SATA Mode’ to ‘AHCI’.
  • Navigate to ‘Boot’ tab and set ‘Secure Boot’ to ‘Enable’ and ‘Load Legacy OPROM’ to ‘Disable’.
  • Boot Mode should be set to ‘UEFI’.
  • Save the settings and Exit from the BIOS.
Once the system restarts, Go to the ‘One Time Boot Menu’ by pressing F12 at the Dell logo 6-7 times.
Select the boot device under UEFI to boot.
In case you have other problems in installing Windows update, check out those methods.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Dan groulx sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 36
Her zaman: 2,089
